sdFinishReboot
Posted 04 June 2001 - 16:15
Posted 04 June 2001 - 19:12
Is your machine 9x? I think I read there have been instances of this on 9x. (?) Might check out the bug list on IS' website. If nt, verify that the setup and ikernel terminate from the taskbar. IS will not reboot unless all IS processes are complete.
One other thing... Have you made a custom dialog box with this dialog? (I do to get rid of all buttons except Cancel.) If so, verify you have the same resource ids used by the original dialog.
Posted 04 June 2001 - 19:14
Here is the piece of code in the firstuiafter event
MessageBox("first ui after",INFORMATION);
Disable(STATUSEX);
BATCH_INSTALL=TRUE;
ShowObjWizardPages(NEXT);
szMsg1 = "";
szMsg2 = "";
nresult = SdFinishReboot (szTitle, szMsg1, SYS_BOOTMACHINE, szMsg2, 0);
(Edited by marshbear at 7:15 pm on June 4, 2001)
