Hello!
Maybe someone can give me some tipps:
I´m using InstallShield X Express Edition, the installations run mainly on Windows XP Pro.
Normally, our Software is supposed to be installed in the directory C:\<softwarename>. This makes the support a lot more easier.
Therefore, the entry in GENERAL INFORMATION/Product Properties/INSTALLDIR is
C:\<softwarename>.
Some customers want to install the software into a different folder, e.g. D:\<softwarename>. Installing our full software this way is no problem.
But: I designed an update for the full version of the software with InstallShieldX.
The entry in GENERAL INFORMATION/Product Properties/INSTALLDIR in this project is also C:\<softwarename>. But if the customer wants now the update to be installed in D:\<softwarename> by changing the default entry in the respective dialog during installation, the updated software doesn´t work. After clicking the *.exe, Windows Installer wants to reinstall some components endlessly. Looking into the Windows EventViewer shows the event "The resource C\:<softwarename>\ doesn´t exist". Of course it doesn´t, because the installation went completely to D:\<softwarename>.
Does anyone of you have some helpful hints? Thanks a lot!
Changing default installation path by user
ilovecolor
, Apr 25 2007 11:56
Posted 25 April 2007 - 15:21
You can use the AppSearch feature of MSI to search for your main application EXE and then assign the directory it was found in to the INSTALLDIR property.
Posted 25 April 2007 - 18:12
Thanks for you reply
Can you please give me a hint how to implement that with InstallShield Express? Or do I have to write a program for that?
I think that it is rather weird that the problem i´ve described above appears. If there is a possibiltity to choose the install path, why doesn´t the installation of the update in this individual directory work?
