Posted 22 February 2010 - 11:56
Ich habe jetzt nicht soviel Erfahrung mit InstallScript Projekten, aber muss man den entsprechenden Dialog nicht einfach aus dem Script entfernen (in der Funktion "OnFirstUIBefore")
// Beginning of UI Sequence Dlg_Start: nResult = 0;
Dlg_SdWelcome: szTitle = ""; szMsg = ""; //{{IS_SCRIPT_TAG(Dlg_SdWelcome) nResult = SdWelcome( szTitle, szMsg ); //}}IS_SCRIPT_TAG(Dlg_SdWelcome) if (nResult = BACK) goto Dlg_Start;
Dlg_SdLicense2: szTitle = ""; szOpt1 = ""; szOpt2 = ""; //{{IS_SCRIPT_TAG(License_File_Path) szLicenseFile = SUPPORTDIR ^ "License.rtf"; //}}IS_SCRIPT_TAG(License_File_Path) //{{IS_SCRIPT_TAG(Dlg_SdLicense2) nResult = SdLicense2Ex( szTitle, szOpt1, szOpt2, szLicenseFile, bLicenseAccepted, TRUE ); //}}IS_SCRIPT_TAG(Dlg_SdLicense2) if (nResult = BACK) then goto Dlg_SdWelcome; else bLicenseAccepted = TRUE; endif;
Dlg_SdRegisterUser: szMsg = ""; szTitle = ""; //{{IS_SCRIPT_TAG(Dlg_SdRegisterUser) nResult = SdRegisterUser( szTitle, szMsg, szName, szCompany ); //}}IS_SCRIPT_TAG(Dlg_SdRegisterUser) if (nResult = BACK) goto Dlg_SdLicense2;
Dlg_SetupType2: szTitle = ""; szMsg = ""; nResult = CUSTOM; //{{IS_SCRIPT_TAG(Dlg_SetupType2) nResult = SetupType2( szTitle, szMsg, "", nSetupType, 0 ); //}}IS_SCRIPT_TAG(Dlg_SetupType2) if (nResult = BACK) then goto Dlg_SdRegisterUser; else nSetupType = nResult; if (nSetupType != CUSTOM) then szTargetPath = TARGETDIR; nSize = 0; FeatureCompareSizeRequired( MEDIA, szTargetPath, nSize ); if (nSize != 0) then MessageBox( szSdStr_NotEnoughSpace, WARNING ); goto Dlg_SetupType2; endif; endif; endif;
Dlg_SdAskDestPath2: if ((nResult = BACK) && (nSetupType != CUSTOM)) goto Dlg_SetupType2; szTitle = ""; szMsg = ""; if (nSetupType = CUSTOM) then //{{IS_SCRIPT_TAG(Dlg_SdAskDestPath2) nResult = SdAskDestPath2( szTitle, szMsg, szDir ); //}}IS_SCRIPT_TAG(Dlg_SdAskDestPath2) TARGETDIR = szDir; endif; if (nResult = BACK) goto Dlg_SetupType2;
Dlg_SdFeatureTree: if ((nResult = BACK) && (nSetupType != CUSTOM)) goto Dlg_SdAskDestPath2; szTitle = ""; szMsg = ""; szFeatures = ""; nLevel = 2; if (nSetupType = CUSTOM) then //{{IS_SCRIPT_TAG(Dlg_SdFeatureTree) nResult = SdFeatureTree( szTitle, szMsg, TARGETDIR, szFeatures, nLevel ); //}}IS_SCRIPT_TAG(Dlg_SdFeatureTree) if (nResult = BACK) goto Dlg_SdAskDestPath2; endif;
Dlg_SQLServer: nResult = OnSQLServerInitialize( nResult ); if( nResult = BACK ) goto Dlg_SdFeatureTree;
Dlg_ObjDialogs: nResult = ShowObjWizardPages( nResult ); if (nResult = BACK) goto Dlg_SQLServer; Dlg_SdStartCopy2: szTitle = ""; szMsg = ""; //{{IS_SCRIPT_TAG(Dlg_SdStartCopy2) nResult = SdStartCopy2( szTitle, szMsg ); //}}IS_SCRIPT_TAG(Dlg_SdStartCopy2) if (nResult = BACK) goto Dlg_ObjDialogs; // Added in 11.0 - Set appropriate StatusEx static text. SetStatusExStaticText( SdLoadString( IDS_IFX_STATUSEX_STATICTEXT_FIRSTUI ) ); return 0;
end; |
Werden in dieser Sequenz nicht einfach nur die "Script-Dialoge" aufgerufen?
So ruft
| SdRegisterUser( szTitle, szMsg, szName, szCompany ); |
doch z.B. den Dialog zur Eingabe der Firma auf.
Also einfach den ganzen Zweig mit "Dlg_SdRegisterUser:" entfernen und die Rücksprungmarke innerhalb von "Dlg_SetupType2:" entsprechend anpassen.
