I need to rebuild my CA dll:s for each new version of my installer.
The CA:s runs works perfectly well when I manually uninstall previous version and then run the installer of the new version.
It also works if previous version is automatically removed by the installer AND the path where I install the CA dll:s are different from the previous version.
A guess is that the installer software simply loads the old dll (in memory) at the uninstall phase and then when installing the new one, it uses the old dll.
Debugging the installer confirms this and shows that there is two CA dll:s loaded and one of them have a mismatched timestamp.
I've tried to change version of the new CA dll without result.
Does anyone know how to solve this? I don't want to change the dll name for each new version of my installer.
Edited by Ballall, 07 October 2004 - 15:33.
