(Sorry, my english is not good)
Do you know how to register a file extension using Installscript?
Thanks in advance.
Carlos
How to register a file extension with Installscrip
carlost
, Oct 14 2002 15:08
Posted 16 October 2002 - 18:58
i found the following at:
http://isg.ee.ethz.c...det/msi.en.html
i know it does not give you the installshield script but it does identify the registry keys required to perform the association. with a bit of effort you should be able to convert
hope it helps...
Registering a File Extension
If your application uses special file extensions, you might want to register them so that the application gets started when the file gets double clicked, and that there is an icon associated with the file. There are special tables for this in the msi structure (Extension and ProgId) their contents is also used for advertising. In Wise 3.5 there is even a GUI for editing the Contents of the Extensions table. No gui though for the ProgID table which sets up icons for file extensions.
You can also make your own registry entries to create application to file extension relations. The example shows how to register the .dvi extensions to be opened with the yap.exe program.
Link the extension .dvi to the DVI.Document class:
Key: HKLM\SOFTWARE\Classes\.dvi
Value: <default> = "DVI.Document"
Describe the DVI.Document class:
Key: HKLM\SOFTWARE\Classes\DVI.Document
Value: <default> = "DVI Document"
Select Icon #0 from yap.exe which is in the MSI:
Key: HKLM\SOFTWARE\Classes\DVI.Document\DefaultIcon
Value: <default> = "[!yap.exe],0"
How to open the .dvi file if it is double clicked in the Explorer:
Key: HKLM\SOFTWARE\Classes\DVI.Document\shell\open\command
Value: <default> = "[!yap.exe]" "%1"
hope it helps...
