I'm facing a weird issue where I configured an AppSearch to look for a path in the registry. The key exists on both "HKLM\SOFTWARE\Microsoft\Help\v1.0" and "HKLM\SOFTWARE\Wow6432Node\Microsoft\Help\v1.0". The value, in both cases, contains the following value "C:\Program Files\Microsoft Help Viewer\v1.0\" (note that it's "Program Files" and not "Program Files(x86)").
When using the property value that has been set by the AppSearch, I see that the path has been modified to "C:\Program Files (x86)\Microsoft Help Viewer\v1.0\" which of course does not exists.
Is there a way to prevent this from happening?
Jacques.
AppSearch - Registry value changed
BourqueJ
, Mar 23 2010 14:48
Posted 24 March 2010 - 12:24
Did you generate a log to see if anything is changing the property value?
Is that a regular REG_SZ value in registry, or is it a REG_EXPAND_SZ ?
