What causes this and how can I avoid it?
Matt
Posted 21 May 2001 - 16:34
Matt
Posted 23 May 2001 - 17:22
You might also find something in the "System Reboots" topic in the Windows Installer help.
Posted 01 June 2001 - 17:55
When I run setup.exe first time (on a fresh machine) a message box asking me to reboot showed up before 'InstallWelcome' dialog box showed up ie it asked to reboot before installation took place!
Pl suggest ANY way to avoid it.
Ian Blake told that setup.exe checks the version of msi. If it does not find msi or finds an older msi it launches instmsia.exe (on Win 95-ME) or instmsiw.exe (on WinNT). This needs a reboot. After a reboot it can call msiexec to process you installation.
My question is that, Can't i do anything so that it finds the msi/newer version (eg what if i run myproject.msi instead of setup.exe) ...
afterall other standard applications do not ask to reboot before installation takes place.
Pl help.. i am running out of time
Thanks.
