Hello!
With Automation Interface of InstallShield X Project I can create new feature and components and link it together.
I need to add folder paths to WI Directory table and link it to appropriate components.
Can I reach it with InstallShield Automation Interface or other WI scripting?
Add folders to directory table
AntonS
, Jul 26 2004 07:54
Posted 26 July 2004 - 08:23
Use the Windows Installer object model instead of the Installshield automation interface. This object model is essentially just a way to access SQL databases (and an MSI file is as you know a database, and Installshield project files are MSI files in disguise - just the file extension is different).
Posted 26 July 2004 - 08:39
| Use the Windows Installer object model instead of the Installshield automation interface ... |
Thank you!
I try to find fast and simple solution inside InstallShield X, which is Automation Interface, always when it possible.
After any idea exhausted I start update MSI database directly using WI api.
