My install contains a field which the user is allowed to leave blank. When I run setup -r to create a slient install file, That field's value gets recorded as ' ', which causes the silent install to error out with a -3 "Required data not found in the Setup.iss file." in the setup.log file. Is this a known issue? Are there any workarounds so the ' ' gets recorded as a blank ''? I can't customize that part of the install using SilentWriteData/SilentReadData because I am using one the the standard dialog functions which automatically writes it's silent install information.
Here is the part of the script file that causes the problem:
[{A3012770-F162-11D4-A202-00B0D02856AC}-SdShowDlgEdit1-0]
szEdit1=' '
Result=1
Thanks in advance for any help,
Danny
blank fields during silent record
jettaman007
, Sep 24 2002 18:55
