I use the funcation that the InstallShield provides to create a Uninstall Shortcut,
It's OK on WINXP&WIN2K, but there is problem on WIN98&WINME.
CODE:
prototype CreateUninstallShortcut();
function CreateUninstallShortcut()
string strCmdLine;
LIST lstPath;
begin
// For an InstallScript installation:
strCmdLine = DISK1TARGET ^ "Setup.exe";
// For an InstallScript MSI installation:
strCmdLine = UNINSTALL_STRING;
// The path has to be handled differently if you are running
// an InstallScript MSI installation on Windows 9X.
if ( SYSINFO.WIN9X.bWin9X ) then
lstPath = ListCreate( STRINGLIST );
StrGetTokens( lstPath, UNINSTALL_STRING, "/" );
ListGetFirstString( lstPath, strCmdLine );
LongPathToQuote( strCmdLine, TRUE );
strCmdLine = strCmdLine + " /M" + PRODUCT_GUID;
endif;
// Create the shortcut.
AddFolderIcon(FOLDER_PROGRAMS ^ "Uninstall Shortcut", "Run the Uninstall",strCmdLine, "","",0, "", NULL );
end;
who can help me ?Uninstall problem.
stdcplusplus
, Jan 21 2006 03:29
Posted 24 January 2006 - 09:05
If your project type is "InstallScript" (and not "InstallScript MSI") then you should remove all the stuff that applies only to InstallScript MSI from the script sample.
Posted 14 February 2006 - 12:53
Which program?
