I have a BasicMSI project. In that I have merge module that contains a VB6 dll. I need to access that dll during my UI to verify a license. Before, in IS 6.0, I copied the dll to the machine then created the object in script and accessed it's properties that way. It worked great. Now I need a custom action to that same thing. How do I do that? Can I just use the StandardDLL action to do this? I don't want to call a function in the DLL I want to create an object from it. Or, do I need to create a VBScript custom action to do it? If I need VBScript, how do I set a property in the property table to the value returned by my VBScript? Can I call the MSISetProperty function directly from my VBScript? Is there a helpful reference for all these questions?
Thanks for any help you can give.
Jennifer
Accessing DLLs from BasicMSI
jmorgret
, Aug 30 2002 18:03
Posted 30 August 2002 - 18:11
You will need to use a script (e.g. VBScript, InstallScript).
To set a propety use
session.property("YOURPROPERTY") = "bla"
