Hello !
I'm working on InstallShield 2009 (Version 15), and I've been trying to use InstallScript for a few days, without success until now...
The idea is simple and has already been raised in previous topics : I need to give full permissions to user for a specific folder during the set-up.
Typically, in a batch script, it would be the following command :
cacls "c:\my folder" /T /E /G "Users":F
I want to insert this instruction in the set-up produced by InstallShield, and therefore to edit the existing InstallScript.
I added a custom function, setUserRights, which I integrated in the set-up.
But I can't find the right code for this function ...
I noticed there exists built-in functions that can do it now (setObjectPermissions), but unfortunately, they do not seem to exist for InstallShield 2009 (and I cannot upgrade it for a lot of good and bad reasons...).
In previous topics, it was suggested to use the cacls exe file :
InstallScript and folder permission
n_guerin
, Oct 25 2012 16:22
Posted 25 October 2012 - 16:22
Prog = "cacls"; s = "C:\myDirectory"; CmdLine = s + " /e /t /g " + myGroupname+":f"; LaunchAppAndWait ( Prog , CmdLine , LAAW_OPTION_WAIT ); |
I tried with this code ; but it had no effect.
In order to get more information, I tried to create a batch script file (.bat), to write the right line of code into it, and to launch it.
This is the code I wrote :
(knowing that INSTALLDIR is worth something like "C:\Program Files\My Folder\")
#include "Ifx.h" #define TEMP_SCRIPT_DIR "C:\\" #define TEMP_SCRIPT_FILE "temp_script.bat" export prototype SetUserRights(HWND); function SetUserRights(hMSI) STRING szTitle, szMsg, tempString; NUMBER nvFileHandle; begin OpenFileMode (FILE_MODE_APPEND); // Create a new file and leave it open. if (CreateFile (nvFileHandle, TEMP_SCRIPT_DIR, TEMP_SCRIPT_FILE) < 0) then // Report the error. MessageBox ("CreateFile failed.", SEVERE); abort; else // Set the message to write to the file. tempString = INSTALLDIR; //we need to remove the last slash because cacls does not accept it StrRemoveLastSlash (tempString); szMsg = "cacls \"" + tempString + "\" /e /t /g Users:f"; // Append the message to the file. if (WriteLine(nvFileHandle, szMsg) < 0) then // Report the error. MessageBox ("WriteLine failed.", SEVERE); else // Report success. szTitle = "CreateFile & WriteLine"; szMsg = "Successfully created and wrote to %s."; SprintfBox (INFORMATION, szTitle, szMsg, TEMP_SCRIPT_FILE); endif; endif; // Close the file. CloseFile (nvFileHandle); if (LaunchAppAndWait ( TEMP_SCRIPT_DIR^TEMP_SCRIPT_FILE, "" , LAAW_OPTION_WAIT ) < 0) then MessageBox("Unable to launch temp script.", WARNING); else // Report success. SprintfBox (INFORMATION, "Success", "Success"); endif; end; |
Unfortunately, this is not working either : the message boxes indicate success, the batch script is created and filled as I wish; but the folder is still not in full access for the Users group.
Right after the installation, I tried to execute the batch script that had been created : it works fine.
So, I guess the install script does not manage to launch the batch script.
Isn't it the right way to do it ? Does anyone find anything wrong in the code ?
Or has got a working suggestion ?
Thanks in advance for any help !
Nicolas
Posted 26 October 2012 - 13:21
First off, you could add like a pause command to your batch file to further debug the problem and ensure it's actually being ran.
I've always just used WAIT instead of LAAW_OPTION_WAIT for LaunchAppAndWait()'s nOptions parameter though, so I would try that instead.
If you still have problems, then you can also check the value of LAAW_PARAMETERS.nLaunchResult for the launched application's error code and ensure the cacl's return code is passed back in the case of a batch file.
Posted 26 October 2012 - 14:26
Thank you for your help !
Indeed, I did not know the pause command (I'm not used to batch scripts...), very useful in that kind of cases !
The actual problem was that my script was executed too soon : before the folder I needed to share had been created.
I had placed this script in the custom actions sequences ; but I had placed it too soon.
It is now corrected, and it works !
Thanks again !
Thanks again !
