Any help would be greatly appreciated. Thanks!
--Chris Salter
Posted 21 January 2002 - 17:35
--Chris Salter
Posted 21 January 2002 - 18:05
http://groups.google.co.uk/groups?hl=en&th=56406891b8f6f0c2&rnum=1
And here's what he quoted. It came from someone inside InstallShield, but neither Barry nor I can find the source, or even whether it's an actual support document. It seems to be.
"Setups created with Standard project types cannot be run without
administrative privileges. Setups created with Basic MSI project types
can be run without Administrative privileges provided that the setup
itself does not access restricted areas of the machine (System32
directory, HKEY_LOCAL_MACHINE registry hive, etc). You can circumvent the
administrative privileges requirement in either case if the .msi package
is published or advertised through Active Directory on Windows 2000 server
in a managed environment."
If anyone can shed more light on this -- is there more to the bug, is there a workaround, etc -- we would really appreciate it. Thanks again!
