The issue that we have is that this manifest is generated after the installation is built, but we need to install the manifest to the end-user's PC.
One option we have is to build the installation twice. In this situation we would build the installation the first time, generate the manifest and copy it to a directory that would be included by a second build of the installation.
A second option is to add or update the file in the MSI database through automation. I have not attempted anything like this so I am not sure it can be done. Of course, if we are using a media type like the Network media type, we won't be able to access the MSI database since it is wrapped by the setup.exe bootstrapper.
Has anyone faced a similar situation? If yes, what was your solution?
Does anyone have any other suggestions or any additional information you could add to the options I mentioned?
One other note: I would like this to be a process that can be automated. I don't want to have to do something like open Orca to add this file.
Edited by sjimmerson, 28 January 2004 - 19:40.
