while updating my product the error message "Error: 1706 No valid source could be found for product TEST "appear
I didn't face this issue before i made some changes in setup.
I added some new feature in under New Merge Module Holder Object 2
1. DAO 3.50
2. DAO 3.60
3. Microsoft Jet Database Engine 3.51 (English)
and remove the merge module New Merge Module Holder Object 1
1. MFC 6.0
2. MFC 7.0
3. MFC 7.1
4. MFC 7.1 (Localized)
and add code for restart after each install/uninstall/update activity.
if i upgrade my old versions(which donot include this merge module) then there is no issues.
but if i upgrade the version created after this modification then error appears.
E.g. Version 1 has New Merge Module Holder Object 1
Version 2 has New Merge Module Holder Object 2 and New Merge Module Holder Object 1 was removed.
Version 3 has New Merge Module Holder Object 2
Senario1:
If i upgrade version 1 with version 2/3 it works fine.
Senario2:
if i uninstall version Version 1 and then install Version 2 followed by upgrade to Version 3 cause an error.
please help me out to solve this issue as this is very urgent.
Thanks in advance
upgrade error in Installshileld 12
Mona
, Feb 10 2009 08:24
Posted 10 February 2009 - 12:13
Why are you using the merge module holder object in a "InstallScript MSI" project instead of adding the merge modules directly? Or are you using the "InstallScript" project type (as opposed to "InstallScript MSI")?
