Setup And Deployment Projects
ganja
, Oct 26 2004 08:34
Posted 26 October 2004 - 08:34
Have u encounter some error when u create a web setup in .net?
the error is "Unable to build filename/foldername already exist". The cause of it is u have the same foldername/filename in your project?
Does microsoft already fix this one?
Its not really a big issue.. but if u've done making a big project, it can't be avoided to have the same filename in a different folder name especially you are working a website and as a group..
are there any suggestions to this problem?
By the way my Version: Microsoft .net framework 1.1.4322
tnx,
tnx,
Posted 26 October 2004 - 12:33
Have you tried building a compressed build (CAB files). This may help as a workaround. Otherwise I think you would have to set the Source location differently in Directory table, which is not possible in VS.NET.
Posted 27 October 2004 - 04:10
Ive tried building a CAB files but still doesnt work...
It still desame as you make Web Setup project... Hope they are
working with this problem now, by the way do u have any suggestions how
to make web setup instead in VS.net?
Posted 27 October 2004 - 07:04
I'm using InstallShield X Premier to build MSI setups.
Posted 27 October 2004 - 08:28
Is installshield can do what web setup project also does?i mean it can automatically create a virtual directory in IIS?
Posted 28 October 2004 - 08:55
Yes it can create web sites and virtual directories
