I'm using Installshield Dev verison 8. When I use to use Pro version 6, if I needed to modify the directory where a particular file was located, I opened the .fgl file and manually modified it as necessary. (Usually the directory would change like this: H:\DEVEL\7_8_1 to H:\DEVEL\7_8_2 ) I have no control over this method of distributing the files, so it was a snap to simply change the .fgl as I needed.
Now I'm in developer, and I can't find an easy way to do this without manually going into every single Component (I have 30) does anyone know of a way I can do a quick and dirty on this without this long process?
Thanks in Advance.
David
Easy Search and Replace for Component directories
hawkes127
, Sep 16 2003 20:00
Posted 17 September 2003 - 08:33
One option would be the use of path variables.
The other option is the direct editor.
Posted 17 September 2003 - 17:59
Ok, I'm still a novice at developer.. where do I find the direct editor? I feel silly for not using Path Variables now!
