i am running a nested installation, and when i install it i do not see the shortcuts of the nested, only the ones from the parent.
i do not know if this is the way it should be, there isn't much info in the help file of SDK (!!!!).
i also noticed another problem, if i am running the installation on NT4, it does not create an add/remove program for the nested installation, just for the parent. BUT if i run it on WIN2000 it does, i mean add the two programs in the add/remove program. and this is not what i need. how can avoid that?, what do i need to do?.
Thanks in advanced.
