I am writing an installation that will install a standard VB6 .exe file plus supporting files to a client PC.
One of the supporting files is an Excel Add-In. I would like to update Excel during the install process (preferably in OnFirstUIAfter) so when the user runs Excel the Add-In is already registered.
I have found the CreateObject function in the help but there are no examples to show how it can be used. Is this the right way to go?
Installshield and Microsoft Excel
blackellis
, Jul 30 2004 17:43
Posted 31 July 2004 - 13:49
There should be automation help included in Excel, but I remember I had problems finding it. Look for help file on disk and search for "register addin" or similar.
Posted 02 August 2004 - 10:56
Thanks for the reply, I already have the code to run the registration of the Excel Add-In (you are right it does take some time to find it!).
I would like to run it during the Install process and as mentioned cannot find any useful Installscript code on how to use the CreateObject functions.
I have thought of a way around it by writing a small executable outside of Installshield, copying it to the hard drive during installation and then executing it during the final stages, but I would rather do all of the work in one place.
Any help on source code for the CreateObject (and associated functions)functionality would be welcome.
Posted 02 August 2004 - 13:27
I created a VBscript that would export information from an Installshield project to an Excel sheet. I think I used CreateObject there:
http://www.installsi...ps.htm#Manifest
