Can someone explain what values _BrowseProperty takes and when? I tried using the MSI debugger to watch the variable, but I didn't find it!
There's nothing in help about it either!
Thanks!
_BrowseProperty
vladb
, Jun 18 2004 19:38
Posted 19 June 2004 - 11:52
Since it is a lowercase property it is not a persistent property (meaning that it is not passed from the UI sequence to the execute sequence. I would assume it is used in the custom installation dialog as a temporary variable to store the browse to dir selected by the user. This value would then probably be passed to INSTALLDIR Just guessing here however.
Posted 23 June 2004 - 03:39
_BrowseProperty acts as a temporary variable to store the name of the folder that you want to change. This is just the name that install shield have chosen to use.
For example, when you hit the "Change" button, [_BrowseProperty] will be set to have a value of say MYNEWFOLDER.
You then choose your path for MYNEWFOLDER, and the "Ok" button will run a SetTargetPath for MYNEWFOLDER.
Hope that makes sense
