I am a first time user of InstallShield and am having a problem getting started, I have been using the package unit on VB6 does the installShield package the project?.
I used the Project Wizard and entered my .exe, do I have to add all the files and where?.
Do I have to modify the script?.
And could I get a Dummies Guide to install shield?.
InstallShield Help
kintyre1
, Oct 20 2004 20:22
Posted 21 October 2004 - 10:29
Can you please look under Help -> About what your exact InstallShield version is? I suspect it's version 5, i.e. very outdated.
Posted 21 October 2004 - 11:27
not clear what you are trying to say.
Do you use the VisaulStudio version of InstallShield or have you switched to a "full version" recently. If the latter applies, it would help to know the version you are using, like Stephan already said.
btw: there should be a "first steps" within the help menu of the program window ... try this or look into the samples which have been installed, haven't they?
Gruß / regards
Thomas
Thomas
Posted 21 October 2004 - 14:43
Thank you for your help, the version of Install Shield I have is 5.5 Professional. You were right, in Help Library I found what I was looking for in Templates.
Once again thank you for your help.
