Im trying to install, however, it always ends before the files are being copied.
A message saying "The wizard wase interrupted before..." comes up.
In the installer I have custom action and custom code.
Any idea what will cause the problem?
Tried debugging, doesnt help much.
HELP!
Thanks in advanced!
MSI installer prematurely ends
mouy
, Feb 16 2004 05:24
Posted 16 February 2004 - 10:20
You can generate a log file to see where it fails. If your custom actions doesn't retun one of the result codes that are defined in the MSI docs, you should set it to ignore the exit code.
Posted 17 February 2004 - 12:39
Thanks there!
I have set the exit code to ignore and all works fine. =)
