hi all,
i have a custom action writen in vbscript that checks the registry for perticular entry and if the registry entry is found then the property should set to "YES" if not found then set to "NO". i use.
Session.Property("XYZPROPERTY")="YES"
i have another custom action that will run after the property is set. in this custom action when i use
str_var = Session.Property("XYZPROPERTY")
msgbox str_var
the messagebox is EMPTY. I need help.
problem in working with Session Property
ishwar
, Nov 24 2005 09:58
Posted 26 November 2005 - 12:34
Where do you sequence your custom customs? Are they immediate or deferred?
A verbose log (ideally created on MSI 3.1) will tell you all property changes which would also help to debug this.
