As I can see in this log there is an attempt to prompt for credentials, but UAC Dialog didn't started at all! Installation failed for no visible reason whatever.
MSI (s) (2C:A4) [17:24:09:952]: Product not registered: beginning first-time install
MSI (s) (2C:A4) [17:24:09:968]: Product {3D2975E7-DD28-4145-811A-225140FF87F0} is not managed.
MSI (s) (2C:A4) [17:24:10:046]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (2C:A4) [17:24:10:046]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (2C:A4) [17:24:10:077]: MSI_LUA: Elevation required to install product, will prompt for credentials
MSI (s) (2C:A4) [17:26:32:702]: MSI_LUA: Credential Request return = 0x800704C7
This error means "The operation was canceled by the user.". What reason may cause such behaiviour? Is anybody meet with such difficulties?
Reproduced on Vista RC1 build 5600.
No prompt for credentials when install on Vista.
igodunov
, Oct 10 2006 15:21
6 replies to this topic
Posted 10 October 2006 - 15:26
<delete this please>
Edited by Glytzhkof, 10 October 2006 - 15:26.
Posted 10 October 2006 - 15:38
| QUOTE (Glytzhkof @ 2006-10-10 15:25) |
| Is the setup wrapped in a setup.exe ? |
The setup file is msi package.
Posted 10 October 2006 - 16:12
This occures when installation goes on the server side, Install phase already started. Is it possible that server-side process can't interact with UAC control and this error is an effect of this?
Posted 11 October 2006 - 06:43
The latest news is that we can't reproduce this behaviour on live system - only in VMWare environment. I suppose this issue caused by some delays (timeout) when server-side installer process interacts with UAC control under VMWare environment.
Posted 11 October 2006 - 13:03
That does make sense, especially if your VMWare version does not list official support for Vista (which I would believe it doesn't).
