Anyone know if it is possible to declare an array variable in installscript? If so, can you show me some syntax. I do not seem to see this functionality in the documentation.
Installscript Arrays
Steve Rauda
, Apr 21 2001 20:33
Posted 24 April 2001 - 15:53
Steve,
There is a function in installscript called "Resize." ISWI recognises the command but there is no help on it for some strange reason. I found it in "Bob Baker's WI Developers guide" p.547.
Here is the example given in the book:
function Foo()
INT nArray(); //Note no initial size give to array
begin
//Size the array to hold 3 values
Resize(nArray, 3);
nArray(0) = 0;
nArray(1) = 1;
nArray(2) = 2;
//display "Value=1"
SprintfBox(INFORMATION, "Script Test", "Value=%d", nArray(1));
end;
"Resize" I presume supports all the basic data types and structures, 2D arrays are not supported i.e. nArray(1)(2);
And be careful not to make your array smaller than your data or you'll lose some (obviously.)
Hope this helps,
Dave.
This info is copyrighted to Mr.bob and his book. Ta.
