We used InstallShield script in our installation.
Now we decided to remove all script actions to prvent the usage of the InstallShield script engine.
Since I removed the last script based custom action InstallShield 11 creates a Setup.ini file and Setup.exe cannot be launched withoud the file.
My question is: How can I run a Setup.exe without Setup.ini?
How create setup without Setup.ini
SOWI
, Mar 30 2006 12:25
Posted 01 April 2006 - 14:05
The existance of InstallScript actions shouldn't make a difference.
You can use the release wizard to build a single setup.exe which includes everything.
Posted 03 April 2006 - 12:12
I did several tests. The result is:
When I remove the last InstallShield script based custom action from my project the release wizard creates two additonal files "0x0409.ini" and "Setup.ini".
Setup.exe won't start if one of the new files was removed.
I did not(!) modify the release configuration.
Any ideas ??
Any ideas ??
Posted 18 July 2013 - 09:33
You have to choose only "Single Executable" in the "Build Installation" section.
