INSTALLSHIELD 11.5, Basic MSI Project:
I would like to hide Add/Remove Pgm Entry. In the help it is said:
In a Windows Installer–based installation, you can hide your application's entry in the Add/Remove Programs panel by setting the Hide Add/Remove Panel Entry property in the Releases view to Yes.
But I cannot find the Add/Remove Panel Entry property in the Releases view.
Why?
lavocat
, Feb 14 2007 11:54
Posted 14 February 2007 - 12:04
No entry in Release view but I can use these properties:
To hide an application from Add/Remove Programs, set the ARPSYSTEMCOMPONENT property to 1. This property can be set within the Property table of the package, on the command line, or by means of a transform. On operating systems earlier than Windows 2000, setting the ARPNOREMOVE property to 1 will hide the application from Add/Remove Programs. On the Windows 2000 and Windows XP operating systems, ARNOREMOVE disables the Remove button of Add/Remove Programs.
