i'm updating a component (a DLL), but it haven't the same key (it has been deleted and inserted again), can i change the key?
This is the problem :
The patch don't upgrade this DLL. But the clean install yes.
Thanks.
Diego
Component Key
Maradoo
, Aug 26 2002 22:02
Posted 27 August 2002 - 20:32
Depends on the tool you are using...
Posted 30 August 2002 - 16:04
When you select the component (in Setup Design View for instance) you should see a Component Code field in the property grid on the right hand side. Here you can adjust the GUID.
