Is there a way that I use developer 8.0 to develop a wizard based application such that when I run the wizard it doesn't copy any files to the target machine. And also when I re-run the wizard, it shouldn't go to maintenance mode.
Bottom line is that I want to use the installshield as a wizard to do some system configuration and not install it as a product.
Looking forward to your replies.
Vivek Chopra
vivek.chopra@hp.com
Installshield wizard
vichop
, Nov 24 2003 05:17
Posted 24 November 2003 - 08:44
Hmmm, you may be able to create a project with no components and insert custom actions to do the tasks you want to do. Then before InstallInitialize or InstallFiles you would insert a custom action which has an Installscript "abort;" statement in it. This should effectively abort the setup without registering the setup on the system. Note that the abort statement probably rolls back the setup and hence may run your custom actions again when abort is performed. I have never tried this.
