I am trying to install MSDE2000 using the InstallShield MSDE 2000 Object. The installation works with no problem on XP sp1. When I try to install on XP sp2 I get a 1603 fatal error. The error file and line are as follows:
File: D:\BldRoot\Source\ObjectsPro\MSDE 2000 Object\Script Files\setup.rul
Line: 582
Any thoughts?
Thanks, scs
MSDE Install Fails on XP sp2
scsmith1
, Jun 24 2005 17:47
Posted 24 June 2005 - 18:16
I know XP SP2 includes the latest version of MDAC (2.8 currently) and will refuse to accept installation of MDAC 2.8. Maybe this is a similar issue with an OS protection feature causing the script to crash? Just a wild guess. It would help if you could post the code from the area in the script where it crashes.
Posted 24 June 2005 - 18:53
Do you know where I can get access to this setup.rul? The only thing I see is a compiled setup script in the ObjectsPro directory. Line 582 in the main installation program refers to the OnRebooted event.
