I want to modify the string table entry called MY_STRING in my script. This string has to be updated according the option that user has selected for installation.
How can i do this?
Neha
Modify the string table entry through script.
Neha
, Mar 28 2003 11:47
Posted 28 March 2003 - 15:55
I think the string table is considered read only at install time, but you could try simply assigning back to it.
I assume you know that to access an entry you simply precede the the string identifier with an at sign (@).
So for like MY_STRING , you would do:
If this does NOT work, then you'll probably need to settle for using a global string variable which you (re)populate as deemed necessary.
| Code Sample |
| @MY_STRING = "Test"; |
Posted 29 March 2003 - 07:45
This statement doesn't complile. It gives error .
Neha
Neha
Posted 29 March 2003 - 20:47
Oh yeah, that's right. Now that I think about it, I've also wanted to do that before, but the compiler does indeed treat the string table as read only.
Posted 07 April 2003 - 16:54
If you really want to use the string table you could set multiple strings in the string table and use a case statement or group of if statements to assign it depending on your users choice.
For example if you had three possible choices available to your user you could have in the string table
MY_STRING1 = xxx
MY_STRING2 = yyy
MY_STRING3 = zzz
From there in the code you get your user selection and have something like this:
if ( UserSelection = 1 ) then
//process with @MY_STRING1
else if ( UserSelection = 2 ) then
//process with @MY_STRING2
else if ( UserSelection = 3 ) then
//process with @MY_STRING3
endif;
That would work if your MY_STRING data is fairly static and only changes the one time and doesn't get built upon as the install progresses. If you need to continually modify the value of MY_STRING by appending things to it based on multiple selection then you will need to have a String variable in your code that you use to store the current value of your assembled String Table values and you will need multiple String Table values representing each possibility.
Using the same three MY_STRING string table entries above the code would differ like this:
//Define String variable at begining of function
STRING sTemp
//code sample
sTemp = @MY_STRING1;
sTemp = @MY_STRING2;
endif;
if ( UserSelection2 = 1 ) then
sTemp = sTemp + @MY_STRING3;
endif;
Hope this helps.
MY_STRING1 = xxx
MY_STRING2 = yyy
MY_STRING3 = zzz
endif;
STRING sTemp
//code sample
endif;
endif;
Hope this helps.
Posted 07 April 2003 - 18:06
Could you let us know why you want to use a String Table constant instead of a global String variable?
If I knew more about what you're trying to do, I could probably make a better suggestion.
