My apologies upfront being new to Develop 7.04.
My question is this. I would like to make an exact copy of
SdShowDlgEdit3. I have 2 different dialogs to create and I'd like to use SdShowDlgEdit3 as the base. I need to make a copy because the behaviors are different in the 2 dialogs that I need to create. Can't I copy the dialog, give it a new name and then modify the behavior as I want?
Dawn
Modifying dialog behavior
dawn100
, Dec 07 2002 21:44
Posted 09 December 2002 - 02:08
In what terms do you mean modify the behaviour?
Would it be easier to set conditions on the behaviour on that dialog so that different controls and text only work for certain conditions?
Posted 09 December 2002 - 15:31
Thankyou for responding Luke.
I've got 2 dialogs boxes and I'd like to use SdShowDlgEdit3 (thru Design User Interface) for both dialogs.
The first is username
password
verify password.
Its required that Fields 2 and 3 do not echo back what the user types. This can be achieved by modifying the dialog layout and the behavior or field 2 and three.
The second dialog is DSN
Username
Password
In this instance I only need Field three to not echo back what the user types.
Also, the layout for each of these dialog box need to be slightly different.
I'm not sure I understand what you mean by modifying the conditions. Do I do that through Design User Interface feature?
password
verify password.
Username
Password
Posted 11 December 2002 - 23:17
Well I am using Basic Msi project so there might be some differences between this and a standard project, but what you can do is try to set all of the text dialogs, and entry fields to only display when a certain condition is met.
This means that you can have one dialog, and have different functionality for different situations.
Posted 12 December 2002 - 14:41
Thank you Luke,
I'll give it a try. I think I have a better understanding now.
Dawn
Dawn
