Is there a way to get setup.exe to just exit if the same version of the product is already installed?
If you run
setup.exe /s /v"/quiet"
twice, it tries to just install over the top the second time, which breaks our running product.
Don't want setup.exe to uninstall/reinstall
PeterBoucher
, May 31 2006 20:10
Posted 01 June 2006 - 23:23
This would also prevent uninstall. Also such a re-install can happen automatically (repair). So your setup should be written in a way that doesn't break the application if it's executed a second time. Why does it break your app?
Posted 13 June 2006 - 17:14
In the IDE you can set upgrades to Disable, Prompt, or Just upgrade without prompting.
What I want is a way to control what setup.exe does when you run the exact same version a 2nd time.
Should I use an appsearch or is there an easier way?
Peter
Peter
Posted 13 June 2006 - 22:08
You could insert a custom action (e.g. type 19) with an appropriate condition, e.g. Installed and Remove~<>"ALL"
