i have questions:
- Is it a normal behavior ? : when i uninstall my product, a merge module i install with it is uninstall too.
- I create a custom action in my merge module, but it seems it isn't execute when i install my product (which include the merge module ;)) (there isn't any trace in log file!)
How can i put this action in the execute sequence ?
Did i miss something ?
CUSTOM ACTION IN MERGE MODULE
Thomas OD
, Aug 10 2001 15:33
Posted 10 August 2001 - 15:37
Merge modules are uninstalled together with the consuming setup. That is normal behaviour.
You can either call the merge module CA from your main setup, or insert it to the ModuleInstallUserInterface or ModuleInstallExecute sequence tables.
Posted 10 August 2001 - 15:38
how can i call the merge module CA in my main project, it isn't visible...?
Posted 10 August 2001 - 15:42
ok sorry for this newbie mistake, i re-import my mm and i can see my CA.
Thanks.
Thanks.
