HI All,
I have an intresting requirement from a user.
Is there a possibility to uninstall a feature when user clicks on a short cut created for this feature/Component.
Here is what I am trying to do.
I have an app to install, with two features in it.I am creating two folders(Main App, SubApp) and a Short cut in each folder under Start Menu/Programs Menu. Each Short cut is named Uninstall. So if the user select the Short cut under Sub App I need to uninstall the feature called SubApp and with it the short cut. Can this be done?? The uninstall for the main app is easy for me as I am uninstalling the whole app.
I am developing Basic MSI project in IS 7.x Dev.
thank you for your time.
ranjit
Uninstall Feature
ranjit
, Mar 11 2003 21:48
Posted 12 March 2003 - 14:28
You could try to call msiexec with REMOVE=FeatureName command line option.
Posted 12 March 2003 - 22:13
Stefan,
Sorry for sending you a message, I think I clicked on the wrong button and havent realised util I saw this add reply button.
Sorry to bother you with personal mail.
ranjit bendapudi
ranjit bendapudi
Posted 12 March 2003 - 22:17
Stefan,
The suggestion you send gave an error saying Invalid command line arguments.
My Short cut property sheet looks like this.
Arguments = /x {ProductGUID} REMOVE = "SubAPP"
Target = [SystemFoder]Msiexec.exe
If I remove the "REMOVE" part it will remove the whole application.
Any suggestions??
Thank you
Ranjit
Any suggestions??
Thank you
Ranjit
Posted 12 March 2003 - 23:21
the command line should be:
/i {ProducCode} REMOVE=FeatureName
Posted 13 March 2003 - 00:43
Thank you stfan that did the trick. Except that the Feature name should be in "".
Thank you once again.
ranjit
ranjit
