How to get information about MDac_typ.exe is installed in a PC?
If installed, how to get version of that particular mdac_typ.exe?
How to detect MDAC_TYP
Rakesh Gupta
, Apr 22 2002 16:08
Posted 23 April 2002 - 13:04
Get MDAC Version and Check ODBC Drivers
This script allows for checking whether MDAC is installed and which version number it is. It also allows for checking whether certain ODBC drivers are installed, including Jet, SQL Server, Oracle, FoxPro and others. This function replaces GetMDACVersion() that has been here before. The new version works by checking the key MDAC file version so it is more reliable then registry lookup, which will no longer work with Office2000 and Windows2000.
To install MDAC as quietly as possible without reboot, use the following command line.
For MDAC versions up to 2.1 (works still with 2.5):
mdac_typ.exe /q:a /c:\"setup.exe /qn1\"
For MDAC version 2.5 and above:
mdac_typ.exe /q:a /c:\"dasetup.exe /q /n\"
See also:
- Information for obtaining the latest version of MDAC on http://www.installsi...en/tt_winup.htm
the Windows Updates and Add-Ons page
- InstallShield Object to install MDAC and DCOM http://www.installsi...bjects.htm#MDAC
prototype GetMDACVersionFromFile (BYREF BOOL, BYREF STRING)
prototype IsODBCDriverInstalled (BYREF BOOL, STRING) http://www.installsi...DBCVersions.zip (2.488 Bytes) Provided by Daniel Odievich
Source: IS5/6 Samples --> Databases
greetings fouad
See also:
greetings fouad
