Any one have any experience in chngeing the Graphich displayed to the right of the prepare install.
I have changes alll the graphics in the MSI and that works fine as long as you launch the .msi file, but if you launch the setup.exe you see the standard IS graphic.
-Michael
Changeing the graphic that is displayed
ClarkMichael
, Jan 25 2005 18:49
Posted 25 January 2005 - 20:23
I believe this can be set inside of the Setup.ini file under the heading [Setup.bmp]
try something like
[Setup.bmp]
Type=0
try something like
[Setup.bmp]
Type=0
Posted 25 January 2005 - 23:45
I'm dure your on the rioght track, BUt it didn't work, I'll do some investgative work on Setuo.exe om MSDN. MAYBE, they will have a pointer.
Thanks !!
Thanks !!
