I am trying to get 32-bit code to detect if it is running on a 64-bit OS. Here is the code I have and never is able to properly execute the punction
//PROTOTYPES
prototype BOOL KERNEL.IsWow64Process(HWND,POINTER);
//VARIABLES
POINTER pIsWow;
HWND hHwnd ;
//First, Get the Process Hangler
nHwnd = GetWindowHandle (HWND_INSTALL);
//Next, ApiCall to see if Running on WOW64
nvResult = KERNEL.IsWow64Process(hHwnd,pIsWow);
//Parse Results
if pIsWow = 1 then
MessageBox("64-Bit OS",INFORMATION);
abort;
else
MessageBox("Not a 64-Bit OS",INFORMATION);
endif;
Problems with API call
aseyer
, Feb 26 2004 21:28
Posted 27 February 2004 - 14:16
You're misusing the second parameter. Define it as BYREF BOOL and define
BOOL IsWow;
BOOL IsWow;
Posted 27 February 2004 - 17:30
Made the changes, however nvResult is still coming back as 0 (failed).
This call should work on XP systems and above. The documentation says I do not need to call USEDLL on the Kernel, so I don't think that is the issue.
Any other ideas?
Any other ideas?
Posted 29 February 2004 - 17:24
Looks like IsWow64Process wants a process handle, not a window handle. So you would have to pass in the handle to the installscript engine process (which I guess would require another API call)
Posted 01 March 2004 - 19:11
Yep that worked.
For anyone who uses this: This code must only be executed on Windows 2000 and above. IsWow64process is not in 9X or NT kernels. This should work on all flavors (AMD, Prescott, and Itanium) 64-bit operating systems.
Thanks for your help!
Here's the code:
prototype BOOL KERNEL.IsWow64Process(HWND,BYREF BOOL);
prototype HWND KERNEL.GetCurrentProcess();
NUMBER nResult;
HWND hHwnd;
BOOL bIsWow;
hHwnd = KERNEL.GetCurrentProcess();
nvResult = KERNEL.IsWow64Process(hHwnd,bIsWow);
if bIsWow = 1 then
else
endif;
Here's the code:
NUMBER nResult;
HWND hHwnd;
BOOL bIsWow;
if bIsWow = 1 then
else
endif;
Edited by aseyer, 01 March 2004 - 19:13.
