Can I use this with InstallShield DevStudio version 9.0 SP1?
And If Yes, how do I get the program to use it?
Jim
Installing MSI 3 with InstallShield
ConfigControl
, Nov 22 2004 20:10
Posted 23 November 2004 - 09:28
DevStudio 9 doesn't officially support MSI 3. You could try to replace the MSI 2 redist (instmsiw.exe) with the MSI 3 redist (rename it), but this could be a problem if you're installing on NT4 or Win2000 SP2 or below.
Otherwise you could create your own setup launcher to pre-install MSI 3 or upgrade to InstallShield 10.5
Posted 09 March 2005 - 02:55
hi. im using admin studio 6, value pack 1 - which brings it upto installshield 10.5 compatibility. the path you mention above does not exist, i do find it in
\installshield\adminstudio\6.0\repackager\msi3.0
the release wizard enables you to include 3.0 installer in your setup.exe. i did that, and when trying to run the setup.exe on windows 2000 (sp4) it quickly said
"1155: File C:\download\instmsi30.exe not found"
c:\download is where i ran setup.exe from. its almost as if it expected it to be there already. i double checked my release settings to include windows installer 3.0, all files compressed, and extract installer engine from setup.exe. same error.
any ideas?
thanks,
any ideas?
thanks,
Posted 09 March 2005 - 03:44
Solved!
I've figured this one out!! (whew!)
what you need to do if you have this problem with admin studio 6, value pack 1 (vp1) is this....
Copy the directory "MSI3.0" from:
c:\program files\InstallShield\AdminStudio6\6.0\Repackager
to....
c:\program files\InstallShield\AdminStudio6\Editor\Redist\Language Independent\i386
then rebuild your package, and it will work.
to....
Posted 17 June 2005 - 17:34
I am using Installshield 10.5 and I do see that file included in the path :
InstallShield 10.5\Redist\Language Independent\i386\msi3.0\instmsi30.exe
But how do I include it ?
Do I need to create a MergeModule project, by adding this file to the project and include the MSM file created ???
Thanks !!!
Thanks !!!
Posted 17 June 2005 - 17:44
No, the msi3 runtime is installed by the setup.exe launcher. You should be able to select MSI 3 in the release wizard.
