Silent Install
Posted 09 January 2002 - 21:25
From the command line try:
MsiExec /i <package path | product code> /qn
This will run the .msi with no UI
Good Luck
Kurt Schneider
Posted 09 January 2002 - 22:06
I have created my setup.exe in IS7.x.
When you say package what exactly do you mean.
I have one exe that I like to distribute and run, in a silent mode.
Posted 09 January 2002 - 22:20
If you just have a setup.exe that you want to run silently, try this from the command line:
setup.exe /q
Here is an explanation of my first reply
package path refers to the path of the .MSI file:
MsiExec /i "C:\MySetup.msi" /qn
product code refers to the product code property:
MsiExec /i {E53919DB-7B5C-417A-B003-5D3293C8B6C7} /qn
Both of these will give the same silent instalation.
Hope this helps
Kurt Schneider
Posted 09 January 2002 - 22:54
May have been in the old versions of IS but not in IS7.x
I will try the MSI method.
Posted 09 January 2002 - 23:29
Anyways Good Luck
Kurt
