I am using InstallShield developer 7
How I can come to know if any user is installing\uninstalling
the software is in non-admin mode.
I used the following function
if (Is (USER_ADMINISTRATOR, szIsData) = FALSE) then
for checking non admin mode
in onbegin function but it is not working for me.
I just want to give a message box if anybody installs/unistalls
our software in non admin mode.
Can anybody suggest me how I can overcome this problem.
I'll be very thankful as I am facing this problem since long.
Regarding Administrative Privileges Urgent
roas
, Feb 21 2006 11:35
Posted 21 February 2006 - 17:54
You are in the wrong setion of the forum. Which project type are you actually using? "Basic MSI" or "InstallScript MSI" (aka "Standard")
Posted 22 February 2006 - 10:31
"Standard" is the older name for "InstallScript MSI" therefore I'm moving this question to the appropriate forum.
Posted 22 February 2006 - 10:34
"Standard" projects require pre-instalaltion of the InstallShield scripting engine which requires admin privileges if I recall correctly. This happens before your script even starts to run. You may be able to edit the error message, I think it's stored in a language INI file.
