So I tried various ways of creating a response file in record mode but no matter what i passed to my setup.exe no response file was created.
As such I tried to manually create one based off a guide I found here:
Response File Guide
My response file looks like the following
Creating a silent install response file
overlordchin
, Feb 13 2012 18:05
Posted 13 February 2012 - 18:05
| [Installshield Silent] Version=v7.00 File=Response File [Application] Name=My Installer Version=1.0.00 Company=My Company [{C6642AF6-6E27-43C4-9C99-E53257D47EA5}-DlgOrder] Dlg0={C6642AF6-6E27-43C4-9C99-E53257D47EA5}-InstallWelcome Count=3 Dlg1={C6642AF6-6E27-43C4-9C99-E53257D47EA5}-LicenseAgreement Dlg2={C6642AF6-6E27-43C4-9C99-E53257D47EA5}-ReadyToInstall Dlg3={C6642AF6-6E27-43C4-9C99-E53257D47EA5}-SetupCompleteSuccess [{C6642AF6-6E27-43C4-9C99-E53257D47EA5}-InstallWelcome] Result=1 [{C6642AF6-6E27-43C4-9C99-E53257D47EA5}-LicenseAgreement] Result=1 [{C6642AF6-6E27-43C4-9C99-E53257D47EA5}-ReadyToInstall] Result=1 [{C6642AF6-6E27-43C4-9C99-E53257D47EA5}-SetupCompleteSuccess] Result=1 |
The issue is that when I call my installer with the following arguments it seems to start silently at first but then loads up the dialog sequence anyways.
MySetup.exe -s -f1c:\mytest.iss OR MySetup.exe /s /f1c:\mytest.iss
I also tried putting -0 after each dialog name. The guide shows "SdWelcome-0" But if I navigate to the dialog section of my installer I see the name as "InstallWelcome". I also read it is possible to have a flag set that disallows silent mode or record mode. It is possible this is set in my Installer but I do not know what or where this flag would be.
Edited by overlordchin, 13 February 2012 - 18:06.
Posted 14 February 2012 - 11:08
Response files are for InstallScript setups. If your setup is a Basic MSI project, you can't use a response file.
Posted 22 May 2012 - 19:17
So I was not clever enough in my phrasing of the question to get the response I needed buy thanks to Stefan for responding and pushing me in the direction I needed to actually go I found that I could silently install my msi based installer with msiexec /s /v"/qn" I had assumed the response file was the appropriate. Just wanted to update the post in case someone else bumps into this issue as well.
Posted 23 May 2012 - 17:08
Sorry if my reply was too short and sounded rude. I think, essentially I wanted to ask: "Which project type are you actually using?"
Posted 23 May 2012 - 17:23
Not at all Stefan...
I phrased my question wrong because I didnt know what I really needed or even needed to ask at the time. Your response was helpful in pushing me towards what I really needed. I only added the comment so that anyone who searches the same way I did will find it and get to the solution quicker.
The comment was not intended to offend or infer anything about support of you or anyone else in the community. I am extremely thankful for the level of support and patience you have shown thus far with my posts
