I have a shortcut defined with Arguments = [MYARGS]. I set MYARGS in a VBScript custom action that always executes. Everything works as expected, except when running in Repair mode. In Repair, the value in MYARGS is ignored, and the shortcut Arguments value is left empty. I'm sure that MYARGS is getting set properly, even in Repair mode, because I can display it in a message box.
As a newbie, I'm sure that I'm missing something simple, but could really use a pointer to where to look.
TIA
Regards - Jack H
Setting Shortcut Arguments with Property
JackH
, May 02 2007 07:25
Posted 03 May 2007 - 16:53
Maybe a verbose log file (ideally created with MSI 3.1 or above as this logs proeprty changes) will help you to find the problem.
Posted 04 May 2007 - 02:17
Thanks Stefan,
That did it. In Repair mode, the MYARGS property was ignored ("Ignoring disallowed property"). I had to add it to SecureCustomProperties.
Jack H
Jack H
