In a previous Installscript installaion, we had a dialog that would display different license agreements depending on different user selections made on that dialog.
I'm trying to do the same thing for a MSI installation. I know that the MSI is built with the RTF license agreement inserted into the "Text" field for the scrollabletext control.
My first solution is to make copies of the scrollable text control and hide all but the one that should be showing through conditions.
Instead, I'd like to make a temp row in the control table that is a scrollabletext control and stream the appropriate RTF into the row. I'd then delete the row and create a new one with a different RTF as necessary?
However, I'm having trouble streaming in the file. Anyone know how to do this? I found this in the Help: "The MsiRecordSetStream function sets a record stream field from a file. Stream data cannot be inserted into temporary fields." Could that be my problem?
Or, is there any way that I could somehow just make a custom action with the installscript dialog and have that inserted into the UI sequence?
Modifying License Agreement on the fly
p13
, Aug 25 2005 22:26
Posted 26 August 2005 - 22:21
Yes, looks like this is your problem.
Also the dialog will not automatically refresh if you change the rtf data in the msi table.
