I am using the MSDE 2000 merge modules in my setup, but i have a problem during the second installation. The problem happens when I uninstall the application and then try to install again. At the end of the second installation, an error message pops up: "Setup failed to configure the server. Refer to the server error logs and setup error logs for more information." This error comes during the MSDE installation.
In the log file I could see that the error occurs during the following action:
Executing "C:\Program Files\Microsoft SQL Server\Tools\Binn\cnfgsvr.exe -V 1 -M 1 -U sa -I "MYINSTANCE" -Q "SQL_Latin1_General_CP1_CI_AS""
I cannot install install anymore my application because it comes always this error message.
Does anybody know what should I do? Or what am I doing wrong?
Thanks a lot,
Ajawl
Error during MSDE 2000 installation
Ajawl
, May 28 2003 16:11
Posted 28 May 2003 - 20:21
Looks like the problem documented here:
http://www.installsi...s_msi.htm#wimsm
in section "Setup failed to configure the server." with MSDE 2000 SP3 Merge Modules
Posted 02 June 2003 - 11:05
Thank you for your help.
When I delete the folder "mssql$<instance_name>", as described in the Bugs Bulletin, then I can install again my application.
So, should I always delete this folder with a custom action when I am installing my application at the first time?
I think it is not secure. How can I make sure that this folder is not being used anymore, specially the folder "Data", which can contain user's databases?
Posted 04 June 2003 - 04:42
| QUOTE (Stefan Krueger @ 2003-05-28 19:21) |
| Looks like the problem documented here: http://www.installsi...s_msi.htm#wimsm in section "Setup failed to configure the server." with MSDE 2000 SP3 Merge Modules |
I have been having the same exact problem but this didn't help. I wiped out the MSSQL directory and I'm still getting the error. Anything else I can try?
