I have a custom dialog for a Basic IS Developer project. It has a radio button group with 5 buttons and a check box. If either radio button 4 or radio button 5 are selected, I want do uncheck the checkbox. I have successfully set the checkbox checked by default as well as have successfully enabled/disabled the checkbox depending on the selected radio button. But I need to check/uncheck it as well depending on the selected radio button.
I can't seem to figure this out. I have tried creating a custom action (EnableCheckBox) to set the property referenced by the checkbox (MY_CHK_PROPERTY="Yes") and another one (DisableCheckBox) to set MY_CHK_PROPERTY="No". Then I modified the behavior for the radio button group to DoAction EnableCheckBox/DisableCheckBox depending on the value of the radio button group's property (SELECTED_BUTTON).
Is this even possible? Any ideas? Please help.
Pls Help: Need to check/uncheck checkbox depending
colby
, Apr 23 2003 16:50
Posted 25 April 2003 - 16:05
A checkbox will be checked whenever its associated property exists, no matter what value. To uncheck the box you must remove (undefine) the property. To do this set the property to {}
