1. I make a basic msi project with InstallShield Developer 8
(only one feature with only one component with one (key)file on it)
I tried with this blanc project but the following result appears also with my complex project.
2. I install it choosing "Install this application for:ONLY FOR ME"
into my account with full admin rights
when I look the loggfile: ApplicationUsers = 'OnlyCurrentUser'
3. I log off and then log in into another account (also with full admin rights)
I launch the installer then I'v no choice: the installer make a all user installation
CustomerInformation. Dialog created
MSI © (84:30) [16:00:39:832]: PROPERTY CHANGE: Adding ALLUSERS property. Its value is '1'.
Then if I log off and log into the previous account, I see an new entry into the add/remove program (it's normal) but to uninstall this program I must remove it twice (I click the remove button then the uninstallation occurs but after that the line is still in the add/remove program window and disappears when I uninstall it the second time)
Why this?
ALLUSERS vs OnlyCurrentUser
lavocat
, Jan 10 2006 16:37
Posted 11 January 2006 - 20:29
Double check the conditions on the radio control and the action conditions on the next button. I guess the problem is in there.
