Hi all,
I have some problem running a patch. When i create a patch, the log file indicates that all is fine, but when i run it, some files don't upgrade. In the patch these files have a new version and they are on the same feature, and this feature is indicated as a changed feature in the patch creation wizard.
Any ideas??? Thanks!
Diego.
Patch not upgrade
Maradoo
, Sep 23 2002 21:12
Posted 25 September 2002 - 10:38
Hi Maradoo,
how did you install your patch at the target? Did you use REINSTALL=ALL at command line? The settings for new features and changed features at the patch creation wizard will only affect the update.exe.
Michael.
Michael.
Michael Schroeder
ORBIS Hamburg GmbH
ORBIS Hamburg GmbH
Posted 26 September 2002 - 15:31
I have the same problem when I patch an installation that has been patched up to it's existing level. For example, if I patch a fresh install, everything works. If I patch an install previously patched (i.e. service pack 1 up to service pack 2), nothing upgrades, but I get no errors.
I don't use the command line however. I create an update.exe via Installshield and use Package for The web 4. I am currently using ISWI ver 2.03.
Mike
Posted 27 September 2002 - 15:59
When I make a new package with the same structure of the installed package all works fine. I think this (its not all chequed, but its works) : when i change the ism´s structure the patch don´t work. I call structure to CA´s code. The version 1 have 15 CA, and the new package have 21 CA, some of it with a diferent installscript code. I guess that it does not work in a patch.
is this correct?, i don´t know, but works.
Any other sugestion?
Posted 27 September 2002 - 16:00
Thanks.
Maradoo
Thanks.
Maradoo
