I have 2 products which are to be installed and should work independently, used Basic MSI project(InstallShield 2012 )
Hence I have changed the Product code, Package code , Upgrade code and all the component codes are changed between these 2 packages.
Both the packages are installed successfully. When you uninstall one of them it leaves behind the folders. No files, just empty folders.
Then uninstall the other product, uninstall successful without any folders left behind.
The clue is that The folders it leaves behind are ones where I had chosen Dynamic File Linking and checked the 'Include Subfolders' option.
And the Folder structure is same for both the products.
Anyone faced similar issues?
