When I apply the patch (without commandline parameters) the installation of the patch starts, but I get the error-message:
"1: This installation can not be run directly launching the MSI package; you must run setup.exe."
The setup contains setup.exe, isscript.msi, myapplication.msi, instmsia.exe, instmsiw.exe, data1.cab, setup.ini and 0x0406.ini. The setup was run from setup.exe.
What am I doing wrong? I thought update.exe contained all the command line parameters that was needed.
